Back up Oracle databases running on Azure NetApp Files
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
Creating your file...
If a resource is not yet part of any resource group, you can back up the resource from the Resources page.
In the left navigation pane, select Resources, and then select the appropriate plug-in from the list.
In the Resource page, select Database from the View drop-down list.
In the Resource page, select Use custom name format for Snapshot copy, and then enter a custom name format that you want to use for the Snapshot name.
In the Policies page, perform the following steps:
Select one or more policies from the drop-down list.
Select in the Configure Schedules column for the policy for which you want to configure a schedule.
In the Add schedules for policy policy_name dialog box, configure the schedule, and then select OK.
In the Verification page, perform the following steps:
Select the verification server.
Select the policy for which you want to configure your verification schedule, and then click .
Either select Run verification after backup or Run scheduled verification.
Click OK.
In the Notification page, from the Email preference drop-down list, select the scenarios in which you want to send the emails.
Review the summary, and then click Finish.
Select Back up Now.
In the Backup page, perform the following steps:
If multiple policies are associated with the resource, from the Policy drop-down list, select the policy that you want to use for backup.
Click Backup.
Monitor the operation progress by clicking Monitor > Jobs.
