Back up Oracle resource groups
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
Creating your file...
Your file is ready
You can back up the resource groups that consist of multiple resources. A backup operation on the resource group is performed on all resources defined in the resource group.
Steps
In the left navigation pane, select Resources, and then select the appropriate plug-in from the list.
In the Resources page, select Resource Group from the View list.
In the Resource Groups page, select the resource group that you want to back up, and then select Back up Now.
In the Backup page, perform the following steps:
If multiple policies are associated with the resource group, from the Policy drop-down list, select the policy that you want to use for backup.
Select Backup.
Monitor the operation progress by selecting Monitor > Jobs.
