Back up SQL Server resource groups
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
- Protect IBM Db2
- Protect PostgreSQL
Creating your file...
You can back up the resource groups that consist of multiple resources. A backup operation on the resource group is performed on all resources defined in the resource group.
In the left navigation pane, select Resources, and then select the appropriate plug-in from the list.
In the Resources page, select Resource Group from the View list.
In the Resource Groups page, select the resource group that you want to back up, and then select Back up Now.
In the Backup page, perform the following steps:
If multiple policies are associated with the resource group, from the Policy drop-down list, select the policy that you want to use for backup.
After backup, select Verify to verify the on-demand backup.
Select Backup.
Monitor the operation progress by selecting Monitor > Jobs.
