Create the Azure credential in SnapCenter
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
Creating your file...
Your file is ready
You should create the Azure credential in SnapCenter to access the Azure NetApp account.
Before creating the Azure credential, ensure that you have created the service principal in Azure. The tenant ID, client ID, and secret key associated with the service principal will be required to create the Azure credential.
Steps
In the left navigation pane, click Settings.
In the Settings page, click Credential.
Click New.
In the Credential page, specify the following information required to create the credential.
For this field… Do this… Credential Name
Enter a name for the credential.
Authentication Mode
Select Azure Credential from the drop-down list.
Tenant ID
Enter the tenant ID.
Client ID
Enter the client ID.
Client Secret Key
Enter the client secret key.
Click OK.
