Create backup policies for SAP HANA databases
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
- Protect IBM Db2
- Protect PostgreSQL
Creating your file...
Your file is ready
Before you use SnapCenter to back up SAP HANA database resources, you must create a backup policy for the resource or resource group that you want to back up.
Steps
In the left navigation pane, click Settings.
In the Settings page, click Policies.
Click New.
In the Name page, enter the policy name and description.
In the Settings page, perform the following steps:
Select the backup type.
Select File-based Backup if you want to perform an integrity check of the database.
Select Snapshot Based if you want to create a backup using Snapshot technology.
Specify the schedule type.
In the Retention page, specify the retention settings for the backup type and the schedule type selected.
Replication to secondary storage is not supported. -
Review the summary and click Finish.
