SnapCenter Software 5.0
Considerations for determining backup schedules for SAP HANA database
Contributors netapp-asubhas
The most critical factor in determining a backup schedule is the rate of change for the resource. You might back up a heavily used resource every hour, while you might back up a rarely used resource once a day. Other factors include the importance of the resource to your organization, your service-level agreement (SLA) and your recovery point objective (RPO).
Backup schedules have two parts, as follows:
  • Backup frequency (how often backups are to be performed)
    Backup frequency, also called schedule type for some plug-ins, is part of a policy configuration. For example, you might configure the backup frequency as hourly, daily, weekly, or monthly.
  • Backup schedules (exactly when backups are to be performed
    Backup schedules are part of a resource or resource group configuration. For example, if you have a resource group that has a policy configured for weekly backups, you might configure the schedule to back up every Thursday at 10:00 p.m.
