SnapCenter Software 5.0
Back up resource groups
Contributors netapp-nsriram netapp-soumikd netapp-asubhas
A resource group is a collection of resources on a host. A backup operation on the resource group is performed on all resources defined in the resource group.
Before you begin
  • You must have created a resource group with a policy attached.
  • If you want to back up a resource that has a SnapMirror relationship with a secondary storage, the ONTAP role assigned to the storage user should include the “snapmirror all” privilege. However, if you are using the “vsadmin” role, then the “snapmirror all” privilege is not required.
About this task
You can back up a resource group on demand from the Resources page. If a resource group has a policy attached and a schedule configured, then backups occur automatically according to the schedule.
Steps
  1. In the left navigation pane, select Resources, and then select the appropriate plug-in from the list.
  2. In the Resources page, select Resource Group from the View list.
    You can search the resource group either by entering the resource group name in the search box or by selecting filter icon, and then selecting the tag. You can then select filter icon to close the filter pane.
  3. In the Resource Groups page, select the resource group that you want to back up, and then select Back up Now.
  4. In the Backup page, perform the following steps:
    1. If you associated multiple policies with the resource group, from the Policy drop-down list, select the policy that you want to use for backup.
      If the policy selected for the on-demand backup is associated with a backup schedule, the on-demand backups will be retained based on the retention settings specified for the schedule type.
    2. Select Backup.
  5. Monitor the operation progress by selecting Monitor > Jobs.
