Define a restore and recovery strategy for SAP HANA resources
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
Creating your file...
Your file is ready
You must define a strategy before you restore and recover your database so that you can perform restore and recovery operations successfully.
Steps
Determine the restore strategies supported for manually added SAP HANA resources
Determine the restore strategies supported for auto discovered SAP HANA databases
Decide the type of recovery operations that you want to perform.
