Back up resource groups of custom plug-in resources
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
Creating your file...
You can back up a resource group on demand from the Resources page. If a resource group has a policy attached and a schedule configured, then backups occur automatically according to the schedule.
You must have created a resource group with a policy attached.
If you want to back up a resource that has a SnapMirror relationship to secondary storage, the ONTAP role assigned to the storage user should include the “snapmirror all” privilege. However, if you are using the “vsadmin” role, then the “snapmirror all” privilege is not required.
In the left navigation pane, click Resources, and then select the appropriate plug-in from the list.
In the Resources page, select Resource Group from the View list.
You can search the resource group either by entering the resource group name in the search box or by clicking and selecting the tag. You can then click to close the filter pane.
In the Resource Groups page, select the resource group that you want to back up, and then click Back up Now.
In the Backup page, perform the following steps:
If you have associated multiple policies with the resource group, from the Policy drop-down list, select the policy that you want to use for backup.
If the policy selected for the on-demand backup is associated with a backup schedule, the on-demand backups will be retained based on the retention settings specified for the schedule type.
Click Backup.
Monitor the operation progress by clicking Monitor > Jobs.
In MetroCluster configurations, SnapCenter might not be able to detect a protection relationship after a failover.
If you are backing up application data on VMDKs and the Java heap size for the SnapCenter Plug-in for VMware vSphere is not large enough, the backup might fail. To increase the Java heap size, locate the script file /opt/netapp/init_scripts/scvservice. In that script, the
do_start method
command starts the SnapCenter VMware plug-in service. Update that command to the following:Java -jar -Xmx8192M -Xms4096M
