Predefined environment variables for restore specific prescript and postscript
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
Creating your file...
SnapCenter allows you to use the predefined environment variables when you execute the prescript and postscript while restoring a database.
Supported predefined environment variables for restoring a database
SC_JOB_ID specifies the job ID of the operation.
Example: 257
SC_ORACLE_SID specifies the system identifier of the database.
If the operation involves multiple databases, this will contain database names separated by pipe.
Example: NFSB31
SC_HOST specifies the host name of the database.
This parameter will be populated for application volumes.
Example: scsmohost2.gdl.englabe.netapp.com
SC_OS_USER specifies the operating system owner of the database.
Example: oracle
SC_OS_GROUP specifies the operating system group of the database.
Example: oinstall
SC_BACKUP_NAME specifies the name of the backup.
Examples:
If the database is not running in ARCHIVELOG mode: DATA@RG2_scspr2417819002_07-20-2021_12.16.48.9267_0|LOG@RG2_scspr2417819002_07-20-2021_12.16.48.9267_1
If the database is running in ARCHIVELOG mode: DATA@RG2_scspr2417819002_07-20-2021_12.16.48.9267_0|LOG@RG2_scspr2417819002_07-20-2021_12.16.48.9267_1,RG2_scspr2417819002_07-21-2021_12.16.48.9267_1,RG2_scspr2417819002_07-22-2021_12.16.48.9267_1
SC_BACKUP_ID specifies the ID of the backup.
Examples:
If the database is not running in ARCHIVELOG mode: DATA@203|LOG@205
If the database is running in ARCHIVELOG mode: DATA@203|LOG@205,206,207
SC_RESOURCE_GROUP_NAME specifies the name of the resource group.
Example: RG1
SC_ORACLE_HOME specifies the path of the Oracle home directory.
Example: /ora01/app/oracle/product/18.1.0/db_1
SC_RECOVERY_TYPE specifies the files that are recovered and also the recovery scope.
Example: RESTORESCOPE:usingBackupControlfile=false|RECOVERYSCOPE:allLogs=true,noLogs=false,untiltime=false,untilscn=false.
For information about delimiters, see Supported delimiters.
