Number of backup jobs needed for databases
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
- Protect IBM Db2
- Protect PostgreSQL
Creating your file...
Your file is ready
Factors that determine the number of backup jobs that you need include the size of the database, the number of volumes used, the rate of change of the database, and your Service Level Agreement (SLA).
For database backups, the number of backup jobs that you choose typically depends on the number of volumes on which you placed your databases. For example, if you placed a group of small databases on one volume and a large database on another volume, you might create one backup job for the small databases and one backup job for the large database.
