Disaster recovery of SnapCenter Plug-in for SQL Server
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
- Protect IBM Db2
- Protect PostgreSQL
Creating your file...
Your file is ready
When the SnapCenter Plug-in for SQL Server is down, use the following steps to switch to a different SQL host and recover the data.
Before you begin
The secondary host should have the same operating system, application, and host name as the primary host.
Push the SnapCenter Plug-in for SQL Server to an alternative host using Add host or Modify host page. See Manage hosts for more information.
Steps
Select the host from the Hosts page to modify and install the SnapCenter Plug-in for SQL Server.
(Optional) Replace the SnapCenter Plug-in for SQL Server configuration files from disaster recovery (DR) backup to the new machine.
Import Windows and SQL schedules from the SnapCenter Plug-in for SQL Server folder from the DR backup.
Related information
See the Disaster Recovery APIs video.
