What you can do with the SnapCenter Plug-in for Unix file systems
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
Creating your file...
When the Plug-in for Unix file systems is installed in your environment, you can use SnapCenter to back up, restore, and clone Unix file systems. You can also perform tasks supporting those operations.
Discover resources
Back up Unix file systems
Schedule backup operations
Restore file system backups
Clone file system backups
Monitor backup, restore, and clone operations
Supported configurations
Item | Supported configuration |
Environments |
Operating systems |
File systems |
Protocols |
Multipath |
yes |
Limitations
Mix of RDMs and virtual disks in a volume group is not supported.
File level restore is not supported.
However, you can manually perform file level restore by cloning the backup and then copying the files manually.
Mix of file systems spread across VMDKs coming from both NFS and VMFS datastore is not supported.
NVMe is not supported.
SnapMirror Business Continuity (SM-BC) is not supported.
Provisioning is not supported.
