SnapCenter Software 5.0
Back up Unix file systems
Contributors netapp-soumikd netapp-nsriram
If a resource is not part of any resource group, you can back up the resource from the Resources page.
Steps
  1. In the left navigation pane, select Resources, and the appropriate plug-in from the list.
  2. In the Resources page, select Path from the View list.
  3. Click Filter icon, and then select the host name and the Unix File Systems to filter the resources.
  4. Select the file system that you want to back up.
  5. In the Resources page, you can perform the following steps:
    1. Select the check box, and enter a custom name format that you want to use for the Snapshot name.
      For example, customtext_policy_hostname or resource_hostname. A timestamp is appended to the Snapshot name by default.
  6. In the Application Settings page, perform the following:
    • Select the Scripts arrow and enter the pre and post commands for quiesce, Snapshot, and unquiesce operations. You can also enter the pre commands to be executed before exiting in the event of a failure.
    • Select one of the backup consistency options:
      • Select File System Consistent if you want to ensure that file systems cached data is flushed before creating the backup and no operations are performed on filesystem while creating the backup.
      • Select Crash Consistent if you want to ensure that file systems cached data is flushed before creating the backup.
  7. In the Policies page, perform the following steps:
    1. Select one or more policies from the drop-down list.
      Note You can create a policy by clicking add symbol.
      In the Configure schedules for selected policies section, the selected policies are listed.
    2. Click add symbol in the Configure Schedules column to configure a schedule for the policy you want.
    3. In the Add schedules for policy policy_name window, configure the schedule, and then select OK.
      policy_name is the name of the policy that you have selected.
      The configured schedules are listed in the Applied Schedules column.
  8. In the Notification page, select the scenarios in which you want to send the emails from the Email preference drop-down list.
    You must specify the sender and receiver email addresses, and the subject of the email. If you want to attach the report of the backup operation performed on the resource, select Attach Job Report.
    Note For email notification, you must have specified the SMTP server details using the either the GUI or the PowerShell command Set-SmSmtpServer.
  9. Review the summary, and then click Finish.
    The topology page is displayed.
  10. Click Back up Now.
  11. In the Backup page, perform the following steps:
    1. If you have applied multiple policies to the resource, from the Policy drop-down list, select the policy that you want to use for backup.
      If the policy selected for the on-demand backup is associated with a backup schedule, the on-demand backups will be retained based on the retention settings specified for the schedule type.
    2. Click Backup.
  12. Monitor the operation progress by clicking Monitor > Jobs.
