Cancel clone operations
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
Creating your file...
You can cancel clone operations that are queued.
You should be logged in as the SnapCenter Admin or job owner to cancel clone operations.
You can cancel a queued clone operation from either the Monitor page or the Activity pane.
You cannot cancel a running clone operation.
You can use the SnapCenter GUI, PowerShell cmdlets, or CLI commands to cancel the queued clone operations.
If you selected All members of this role can see and operate on other members objects in Users\Groups page while creating a role, you can cancel the queued clone operations of other members while using that role.
Perform one of the following actions:
From the… | Action |
Monitor page |
Activity pane |
