Install SnapCenter Plug-in for VMware vSphere
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
Creating your file...
Your file is ready
If your database or filesystem is stored on virtual machines (VMs), or if you want to protect VMs and datastores, you must deploy the SnapCenter Plug-in for VMware vSphere virtual appliance.
For information to deploy, see Deployment Overview.
Deploy CA certificate
To configure the CA Certificate with SnapCenter Plug-in for VMware vSphere, see Create or import SSL certificate.
Configure the CRL file
SnapCenter Plug-in for VMware vSphere looks for the CRL files in a pre-configured directory. Default directory of the CRL files for SnapCenter Plug-in for VMware vSphere is /opt/netapp/config/crl.
You can place more than one CRL file in this directory. The incoming certificates will be verified against each CRL.
