Configuring the archive state and counters for TSM
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
If your Archive Node connects to a TSM middleware server, you can configure an Archive Node's archive store state to Online or Offline. You can also disable the archive store when the Archive Node first starts up, or reset the failure count being tracked for the associated alarm.
You must be signed in to the Grid Manager using a supported browser.
You must have specific access permissions.
Select Support > Tools > Grid Topology.
Select Archive Node > ARC > Store.
Select Configuration > Main.
Modify the following settings, as necessary:
Store State: Set the component state to either:
Online: The Archive Node is available to process object data for storage to the archival storage system.
Offline: The Archive Node is not available to process object data for storage to the archival storage system.
Archive Store Disabled on Startup: When selected, the Archive Store component remains in the Read-only state when restarted. Used to persistently disable storage to the targeted the archival storage system. Useful when the targeted the archival storage system is unable to accept content.
Reset Store Failure Count: Reset the counter for store failures. This can be used to clear the ARVF (Stores Failure) alarm.
Click Apply Changes.
