Configuring stored object hashing
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
The Stored Object Hashing option specifies the hashing algorithm used to verify object integrity.
What you'll need
You must be signed in to the Grid Manager using a supported browser.
You must have specific access permissions.
About this task
By default, object data is hashed using the SHA‐1 algorithm. The SHA-256 algorithm requires additional CPU resources and is generally not recommended for integrity verification.
If you change this setting, it will take about one minute for the new setting to be applied. The configured value is cached for performance and scaling. |
Steps
Select Configuration > System Settings > Grid Options.
In the Stored Object Options section, change Stored Object Hashing to SHA-1 (default) or SHA-256.
Click Save.
