Managing local users
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
You can create local users and assign them to local admin groups to determine which Grid Manager features these users can access.
The Grid Manager includes one predefined local user, named “root.” Although you can add and remove local users, you cannot remove the root user.
If single sign-on (SSO) has been enabled, local users cannot sign in to StorageGRID. |
You must be signed in to the Grid Manager using a supported browser.
You must have specific access permissions.
Creating a local user
If you have created local admin groups, you can create one or more local users and assign each user to one or more groups. The group's permissions control which Grid Manager features the user can access.
You can only create local users, and you can only assign these users to local admin groups. Federated users and federated groups are managed using the external identity source.
Select Configuration > Access Control > Admin Users.
Click Create.
Enter the user's display name, unique name, and password.
Assign the user to one or more groups that govern the access permissions.
The list of group names is generated from the Groups table.
Click Save.
Modifying a local user's account
You can modify a local admin user's account to update the user's display name or group membership. You can also temporarily prevent a user from accessing the system.
You can edit local users only. Federated user details are automatically synchronized with the external identity source.
Select the user you want to edit.
If your system includes more than 20 items, you can specify how many rows are shown on each page at one time. You can then use your browser's find feature to search for a specific item in the currently displayed rows.
Click Edit.
Optionally, make changes to the name or group membership.
Optionally, to prevent the user from accessing the system temporarily, check Deny Access.
Click Save.
The new settings are applied the next time the user signs out and then signs back in to the Grid Manager.
Deleting a local user's account
You can delete accounts for local users that no longer require access to the Grid Manager.
Select the local user you want to delete.
You cannot delete the predefined root local user. If your system includes more than 20 items, you can specify how many rows are shown on each page at one time. You can then use your browser's find feature to search for a specific item in the currently displayed rows.
Click Remove.
Click OK.
Changing a local user's password
Local users can change their own passwords using the Change Password option in the Grid Manager banner. In addition, users who have access to the Admin Users page can change passwords for other local users.
You can change passwords for local users only. Federated users must change their own passwords in the external identity source.
From the Users page, select the user.
Click Change Password.
Enter and confirm the password, and click Save.
