Monitoring data migration
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Data migration must be monitored and adjusted as necessary to ensure data is placed according to the ILM policy within the required timeframe.
This table lists the attributes you must monitor during data migration, and the issues that they represent.
If you use traffic classification policies with rate limits to throttle ingest, you can monitor the observed rate in conjunction with the statistics described in the following table and reduce the limits if necessary.
Monitor | Description |
Number of objects waiting for ILM evaluation |
Targeted archival system's storage capacity |
If the ILM policy saves a copy of the migrated data to a targeted archival storage system (tape or the cloud), monitor the capacity of the targeted archival storage system to ensure that there is sufficient capacity for the migrated data. |
Archive Node > ARC > Store |
If an alarm for the Store Failures (ARVF) attribute is triggered, the targeted archival storage system might have reached capacity. Check the targeted archival storage system and resolve any issues that triggered an alarm. |
