Signing in to the Grid Manager
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
You access the Grid Manager sign-in page by entering the fully qualified domain name (FQDN) or IP address of an Admin Node into the address bar of a supported web browser.
You must have your login credentials.
You must have the URL for the Grid Manager.
You must be using a supported web browser.
Cookies must be enabled in your web browser.
You must have specific access permissions.
Each StorageGRID system includes one primary Admin Node and any number of non-primary Admin Nodes. You can sign in to the Grid Manager on any Admin Node to manage the StorageGRID system. However, the Admin Nodes are not exactly the same:
Alarm acknowledgments (legacy system) made on one Admin Node are not copied to other Admin Nodes. For this reason, the information displayed for alarms might not look the same on each Admin Node.
Some maintenance procedures can only be performed from the primary Admin Node.
If Admin Nodes are included in a high availability (HA) group, you connect using the virtual IP address of the HA group or a fully qualified domain name that maps to the virtual IP address. The primary Admin Node should be selected as the group's preferred Master, so that when you access the Grid Manager, you access it on the primary Admin Node unless the primary Admin Node is not available.
Launch a supported web browser.
In the browser's address bar, enter the URL for the Grid Manager:
https://FQDN_or_Admin_Node_IP/
where
is a fully qualified domain name or the IP address of an Admin Node or the virtual IP address of an HA group of Admin Nodes.If you must access the Grid Manager on a port other than the standard port for HTTPS (443), enter the following, where
is a fully qualified domain name or IP address, and port is the port number:https://FQDN_or_Admin_Node_IP:port/
If you are prompted with a security alert, install the certificate using the browser's installation wizard.
Sign in to the Grid Manager:
If single sign-on (SSO) is not being used for your StorageGRID system:
Enter your username and password for the Grid Manager.
Click Sign In.
If SSO is enabled for your StorageGRID system and this is the first time you have accessed the URL on this browser:
Click Sign in. You can leave the Account ID field blank.
Enter your standard SSO credentials on your organization's SSO sign-in page. For example:
If SSO is enabled for your StorageGRID system and you have previously accessed the Grid Manager or a tenant account:
Do either of the following:
Enter 0 (the account ID for the Grid Manager), and click Sign in.
Select Grid Manager if it appears in the list of recent accounts, and click Sign in.
Sign in with your standard SSO credentials on your organization's SSO sign-in page. When you are signed in, the home page of the Grid Manager appears, which includes the Dashboard. To learn what information is provided, see “Viewing the Dashboard” in the instructions for monitoring and troubleshooting StorageGRID.
If you want to sign in to another Admin Node:
Option Steps SSO not enabled
In the browser's address bar, enter the fully qualified domain name or IP address of the other Admin Node. Include the port number as required.
Click Sign In.
SSO enabled
If you have signed in to one Admin Node, you can access other Admin Nodes without having to sign in again. However, if your SSO session expires, you are prompted for your credentials again.
Note: SSO is not available on the restricted Grid Manager port. You must use the default HTTPS port (443) if you want users to authenticate with single sign-on.
