APCT: Archive Purge from Cloud-Tier
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
This message is generated when archived object data is deleted from an external archival storage system, which connects to the StorageGRID through the S3 API.
Code | Field | Description |
CBID |
Content Block ID |
The unique identifier for the content block that was deleted. |
CSIZ |
Content Size |
The size of the object in bytes. Always returns 0. |
RSLT |
Result Code |
Returns successful (SUCS) or the error reported by the backend. |
SUID |
Storage Unique Identifier |
Unique identifier (UUID) of the cloud-tier from which the object was deleted. |
