ARCB: Archive Object Retrieve Begin
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
This message is generated when a request is made to retrieve archived object data and the retrieval process begins. Retrieval requests are processed immediately, but can be reordered to improve efficiency of retrieval from linear media such as tape.
Code | Field | Description |
CBID |
Content Block ID |
The unique identifier of the Content Block to be retrieved from the external archival storage system. |
RSLT |
Result |
Indicates the result of starting the archive retrieval process. Currently defined value is:SUCS: The content request was received and queued for retrieval. |
This audit message marks the time of an archive retrieval. It allows you to match the message with a corresponding ARCE end message to determine the duration of archive retrieval, and whether the operation was successful.
