Adding storage capacity
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
When existing Storage Nodes become full, you must increase the storage capacity of your StorageGRID system.
To increase storage capacity, you must first understand where data is stored currently and then add capacity in all required locations. For example, if you currently store copies of object data at several sites, you might need to increase the storage capacity of each site.
