Copying audit logs
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
When you add a new Admin Node through an expansion procedure, its AMS service only logs events and actions that occur after it joins the system. You can copy audit logs from a previously installed Admin Node to the new expansion Admin Node so that it is in sync with the rest of the StorageGRID system.
You must have completed the required expansion steps to add an Admin Node.
You must have the
Passwords.txt
file.
To make the historical audit messages from other Admin Nodes available on the expansion Admin Node, you must copy the audit log files manually from the primary Admin Node, or another existing Admin Node, to the expansion Admin Node.
Log in to the primary Admin Node:
Enter the following command:
ssh admin@_primary_Admin_Node_IP
Enter the password listed in the
Passwords.txt
file. -
Enter the following command to switch to root:
su -
Passwords.txt
file.When you are logged in as root, the prompt changes from
to#
Stop the AMS service to prevent it from creating a new file:
service ams stop
Rename the
audit.log
file to ensure that it does not overwrite the file on the expansion Admin Node you are copying it to:cd /var/local/audit/export
ls -l
mv audit.log new_name.txt
Copy all audit log files to the expansion Admin Node:
scp -p * IP_address:/var/local/audit/export
If prompted for the passphrase for
/root/.ssh/id_rsa
, enter the SSH Access Password for the Primary Admin Node listed in thePasswords.txt
file. -
Restore the original
audit.log
file:mv new_name.txt audit.log
Start the AMS service:
service ams start
Log out from the server:
exit
Log in to the expansion Admin Node:
ssh admin@expansion_Admin_Node_IP
Passwords.txt
file. -
su -
Passwords.txt
to#
Update the user and group settings for the audit log files:
chown ams-user:bycast *
exit
