Copying Prometheus metrics
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
After adding a new Admin Node, you can optionally copy the historical metrics maintained by Prometheus from the primary Admin Node to the new Admin Node. Copying the metrics ensures that historical metrics are consistent between Admin Nodes.
The new Admin Node must be installed and running.
You must have the
Passwords.txt
file. -
You must have the provisioning passphrase.
When you add an Admin Node, the software installation process creates a new Prometheus database. You can keep the historical metrics consistent between nodes by copying the Prometheus database from the primary Admin Node (the source Admin Node) to the new Admin Node.
Copying the Prometheus database might take an hour or more. Some Grid Manager features will be unavailable while services are stopped on the source Admin Node. |
Log in to the source Admin Node:
Enter the following command:
ssh admin@grid_node_IP
Enter the password listed in the
Passwords.txt
file. -
Enter the following command to switch to root:
su -
Passwords.txt
file.
From the source Admin Node, stop the Prometheus service:
service prometheus stop
Complete the following steps on the new Admin Node:
Log in to the new Admin Node:
Passwords.txt
file. -
su -
Passwords.txt
file.
Stop the Prometheus service:
Add the SSH private key to the SSH agent. Enter:
ssh-add
Enter the SSH Access Password listed in the
Passwords.txt
file. -
Copy the Prometheus database from the source Admin Node to the new Admin Node:
/usr/local/prometheus/bin/prometheus-clone-db.sh Source_Admin_Node_IP
When prompted, press Enter to confirm that you want to destroy the new Prometheus database on the new Admin Node.
The original Prometheus database and its historical data are copied to the new Admin Node. When the copy operation is done, the script starts the new Admin Node. The following status appears:
Database cloned, starting services
When you no longer require passwordless access to other servers, remove the private key from the SSH agent. Enter:
ssh-add -D
Restart the Prometheus service on the source Admin Node.
service prometheus start
