Creating a traffic classification policy for FabricPool
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
You can optionally design a StorageGRID traffic classification policy to optimize quality of service for the FabricPool workload.
You must be signed in to the Grid Manager using a supported browser.
You must have the Root Access permission.
The best practices for creating a traffic classification policy for FabricPool depend on the workload, as follows:
If you plan to tier FabricPool primary workload data to StorageGRID, you should ensure that the FabricPool workload has the majority of bandwidth. You can create a traffic classification policy to limit all other workloads.
In general, FabricPool read operations are more important to prioritize than write operations. For example, if other S3 clients use this StorageGRID system, you should create a traffic classification policy. You can limit network traffic for the other buckets, tenants, IP subnets, or load balancer endpoints.
As a general rule, you should not impose quality of service limits on any FabricPool workload; you should only limit the other workloads.
The limits placed on other workloads might need to be broad to account for the unknown behavior of those workloads. The limits imposed will also vary based on the sizing and capabilities of your grid and what the expected amount of utilization is.
To learn more: Managing traffic classification policies
Select Configuration > Network Settings > Traffic Classification.
Enter a name and a description.
In the Matching Rules section, create at least one rule.
Select Create.
Select Endpoint, and select the load balancer endpoint you created for FabricPool.
You can also select the FabricPool tenant account or bucket.
If you want this traffic policy to limit traffic for the other endpoints, select Inverse Match.
Optionally, create one or more limits.
Even if no limits are set for a traffic classification policy, metrics are collected so you can understand traffic trends. -
Select Create.
Select the type of traffic you want to limit and the limit to apply.
This example FabricPool traffic classification lists the types of network traffic you can limit and the types of values you can select. The traffic types and values for an actual policy would be based on your specific requirements.
After creating the traffic classification policy, select the policy and then select Metrics to determine if the policy is limiting traffic as expected.
