Configuring Erasure Coding profiles
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
You configure Erasure Coding profiles by associating a storage pool with an erasure-coding scheme, such as 6+3. Then, when you configure the placement instructions for an ILM rule, you can select the Erasure Coding profile. If an object matches the rule, data and parity fragments are created and distributed to the storage locations in the storage pool according to the erasure-coding scheme.
