Gathering required materials for grid node recovery
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Before performing maintenance procedures, you must ensure you have the necessary materials to recover a failed grid node.
Item | Notes |
StorageGRID installation archive |
If you need to recover a grid node, you need the StorageGRID installation archive for your platform. Note: You do not need to download files if you are recovering failed storage volumes on a Storage Node. |
Recovery Package |
Obtain a copy of the most recent Recovery Package The contents of the If the primary Admin Node is operating normally, you can download the Recovery Package from the Grid Manager. Select Maintenance > System > Recovery Package. If you cannot access the Grid Manager, you can find encrypted copies of the Recovery Package on some Storage Nodes that contain the ADC service. On each Storage Node, examine this location for the Recovery Package: |
Contains the passwords required to access grid nodes on the command line. Included in the Recovery Package. |
Provisioning passphrase |
The passphrase is created and documented when the StorageGRID system is first installed. The provisioning passphrase is not in the |
Current documentation for your platform |
For the current supported versions of your platform, see the Interoperability Matrix Tool. Go to the platform vendor's website for documentation. |
Downloading and extracting the StorageGRID installation files
