Preparing an appliance Storage Node for reinstallation
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
When recovering an appliance Storage Node, you must first prepare the appliance for reinstallation of StorageGRID software.
Log in to the failed Storage Node:
Enter the following command:
ssh admin@grid_node_IP
Enter the password listed in the
Passwords.txt
file. -
Enter the following command to switch to root:
su -
Passwords.txt
file.
When you are logged in as root, the prompt changes from
to#
Prepare the appliance Storage Node for the installation of StorageGRID software.
sgareinstall
When prompted to continue, enter:
y
The appliance reboots, and your SSH session ends. It usually takes about 5 minutes for the StorageGRID Appliance Installer to become available, although in some cases you might need to wait up to 30 minutes.
The StorageGRID appliance Storage Node is reset, and data on the Storage Node is no longer accessible. IP addresses configured during the original installation process should remain intact; however, it is recommended that you confirm this when the procedure completes.
After executing the
sgareinstall
command, all StorageGRID-provisioned accounts, passwords, and SSH keys are removed, and new host keys are generated.
