Resetting the preferred sender on the recovered primary Admin Node
Contributors netapp-lhalbert
If the primary Admin Node you are recovering is currently set as the preferred sender of alert notifications, alarm notifications, and AutoSupport messages, you must reconfigure this setting.
What you'll need
  • You must be signed in to the Grid Manager using a supported browser.
  • You must have specific access permissions.
  • The recovered Admin Node must be installed and running.
Steps
  1. Select Configuration > System Settings > Display Options.
  2. Select the recovered Admin Node from the Preferred Sender drop-down list.
  3. Click Apply Changes.
Related information
Administer StorageGRID
