Restoring the Admin Node database when recovering a non-primary Admin Node
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
If you want to retain the historical information about attributes, alarms, and alerts on a non-primary Admin Node that has failed, you can restore the Admin Node database from the primary Admin Node.
The recovered Admin Node must be installed and running.
The StorageGRID system must include at least two Admin Nodes.
You must have the
Passwords.txt
file. -
You must have the provisioning passphrase.
If an Admin Node fails, the historical information stored in its Admin Node database is lost. This database includes the following information:
Alert history
Alarm history
Historical attribute data, which is used in the charts and text reports available from the Support > Tools > Grid Topology page.
When you recover an Admin Node, the software installation process creates an empty Admin Node database on the recovered node. However, the new database only includes information for servers and services that are currently part of the system or added later.
If you restored a non-primary Admin Node, you can restore the historical information by copying the Admin Node database from the primary Admin Node (the source Admin Node) to the recovered node.
Copying the Admin Node database might take several hours. Some Grid Manager features will be unavailable while services are stopped on the source node. |
Log in to the source Admin Node:
Enter the following command:
ssh admin@grid_node_IP
Enter the password listed in the
Passwords.txt
file. -
Enter the following command to switch to root:
su -
Passwords.txt
file.
Run the following command from the source Admin Node. Then, enter the provisioning passphrase if prompted.
recover-access-points
From the source Admin Node, stop the MI service:
service mi stop
From the source Admin Node, stop the Management Application Program Interface (mgmt-api) service:
service mgmt-api stop
Complete the following steps on the recovered Admin Node:
Log in to the recovered Admin Node:
Passwords.txt
file. -
su -
Passwords.txt
file.
Stop the MI service:
service mi stop
Stop the mgmt-api service:
Add the SSH private key to the SSH agent. Enter:
ssh-add
Enter the SSH Access Password listed in the
Passwords.txt
file. -
Copy the database from the source Admin Node to the recovered Admin Node:
/usr/local/mi/bin/mi-clone-db.sh Source_Admin_Node_IP
When prompted, confirm that you want to overwrite the MI database on the recovered Admin Node.
The database and its historical data are copied to the recovered Admin Node. When the copy operation is done, the script starts the recovered Admin Node.
When you no longer require passwordless access to other servers, remove the private key from the SSH agent. Enter:
ssh-add -D
Restart the services on the source Admin Node:
service servermanager start
