Error codes in bycast.log
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Most of the error messages in bycast.log
contain error codes.
The following table lists common non-numerical codes in bycast.log
. The exact meaning of a non-numerical code depends on the context in which it is reported.
Error code | Meaning |
SUCS |
No error |
GERR |
Unknown |
CANC |
Canceled |
ABRT |
Aborted |
TOUT |
Timeout |
INVL |
Invalid |
NFND |
Not found |
VERS |
Version |
CONF |
Configuration |
FAIL |
Failed |
ICPL |
Incomplete |
DONE |
Done |
SUNV |
Service unavailable |
The following table lists the numerical error codes in bycast.log
Error number | Error code | Meaning |
001 |
EPERM |
Operation not permitted |
002 |
ENOENT |
No such file or directory |
003 |
ESRCH |
No such process |
004 |
EINTR |
Interrupted system call |
005 |
EIO |
I/O error |
006 |
ENXIO |
No such device or address |
007 |
E2BIG |
Argument list too long |
008 |
ENOEXEC |
Exec format error |
009 |
EBADF |
Bad file number |
010 |
ECHILD |
No child processes |
011 |
EAGAIN |
Try again |
012 |
ENOMEM |
Out of memory |
013 |
EACCES |
Permission denied |
014 |
EFAULT |
Bad address |
015 |
ENOTBLK |
Block device required |
016 |
EBUSY |
Device or resource busy |
017 |
EEXIST |
File exists |
018 |
EXDEV |
Cross-device link |
019 |
ENODEV |
No such device |
020 |
ENOTDIR |
Not a directory |
021 |
EISDIR |
Is a directory |
022 |
EINVAL |
Invalid argument |
023 |
ENFILE |
File table overflow |
024 |
EMFILE |
Too many open files |
025 |
ENOTTY |
Not a typewriter |
026 |
ETXTBSY |
Text file busy |
027 |
EFBIG |
File too large |
028 |
ENOSPC |
No space left on device |
029 |
ESPIPE |
Illegal seek |
030 |
EROFS |
Read-only file system |
031 |
EMLINK |
Too many links |
032 |
EPIPE |
Broken pipe |
033 |
EDOM |
Math argument out of domain of func |
034 |
ERANGE |
Math result not representable |
035 |
EDEADLK |
Resource deadlock would occur |
036 |
ENAMETOOLONG |
File name too long |
037 |
ENOLCK |
No record locks available |
038 |
ENOSYS |
Function not implemented |
039 |
ENOTEMPTY |
Directory not empty |
040 |
ELOOP |
Too many symbolic links encountered |
041 |
042 |
ENOMSG |
No message of desired type |
043 |
EIDRM |
Identifier removed |
044 |
ECHRNG |
Channel number out of range |
045 |
EL2NSYNC |
Level 2 not synchronized |
046 |
EL3HLT |
Level 3 halted |
047 |
EL3RST |
Level 3 reset |
048 |
ELNRNG |
Link number out of range |
049 |
EUNATCH |
Protocol driver not attached |
050 |
ENOCSI |
No CSI structure available |
051 |
EL2HLT |
Level 2 halted |
052 |
EBADE |
Invalid exchange |
053 |
EBADR |
Invalid request descriptor |
054 |
EXFULL |
Exchange full |
055 |
ENOANO |
No anode |
056 |
EBADRQC |
Invalid request code |
057 |
EBADSLT |
Invalid slot |
058 |
059 |
EBFONT |
Bad font file format |
060 |
ENOSTR |
Device not a stream |
061 |
ENODATA |
No data available |
062 |
ETIME |
Timer expired |
063 |
ENOSR |
Out of streams resources |
064 |
ENONET |
Machine is not on the network |
065 |
ENOPKG |
Package not installed |
066 |
EREMOTE |
Object is remote |
067 |
ENOLINK |
Link has been severed |
068 |
EADV |
Advertise error |
069 |
ESRMNT |
Srmount error |
070 |
ECOMM |
Communication error on send |
071 |
EPROTO |
Protocol error |
072 |
EMULTIHOP |
Multihop attempted |
073 |
EDOTDOT |
RFS specific error |
074 |
EBADMSG |
Not a data message |
075 |
EOVERFLOW |
Value too large for defined data type |
076 |
ENOTUNIQ |
Name not unique on network |
077 |
EBADFD |
File descriptor in bad state |
078 |
EREMCHG |
Remote address changed |
079 |
ELIBACC |
Cannot access a needed shared library |
080 |
ELIBBAD |
Accessing a corrupted shared library |
081 |
ELIBSCN |
082 |
ELIBMAX |
Attempting to link in too many shared libraries |
083 |
ELIBEXEC |
Cannot exec a shared library directly |
084 |
EILSEQ |
Illegal byte sequence |
085 |
ERESTART |
Interrupted system call should be restarted |
086 |
ESTRPIPE |
Streams pipe error |
087 |
EUSERS |
Too many users |
088 |
ENOTSOCK |
Socket operation on non-socket |
089 |
EDESTADDRREQ |
Destination address required |
090 |
EMSGSIZE |
Message too long |
091 |
EPROTOTYPE |
Protocol wrong type for socket |
092 |
ENOPROTOOPT |
Protocol not available |
093 |
EPROTONOSUPPORT |
Protocol not supported |
094 |
ESOCKTNOSUPPORT |
Socket type not supported |
095 |
EOPNOTSUPP |
Operation not supported on transport endpoint |
096 |
EPFNOSUPPORT |
Protocol family not supported |
097 |
EAFNOSUPPORT |
Address family not supported by protocol |
098 |
EADDRINUSE |
Address already in use |
099 |
EADDRNOTAVAIL |
Cannot assign requested address |
100 |
ENETDOWN |
Network is down |
101 |
ENETUNREACH |
Network is unreachable |
102 |
ENETRESET |
Network dropped connection because of reset |
103 |
ECONNABORTED |
Software caused connection abort |
104 |
ECONNRESET |
Connection reset by peer |
105 |
ENOBUFS |
No buffer space available |
106 |
EISCONN |
Transport endpoint is already connected |
107 |
ENOTCONN |
Transport endpoint is not connected |
108 |
ESHUTDOWN |
Cannot send after transport endpoint shutdown |
109 |
ETOOMANYREFS |
Too many references: cannot splice |
110 |
ETIMEDOUT |
Connection timed out |
111 |
ECONNREFUSED |
Connection refused |
112 |
EHOSTDOWN |
Host is down |
113 |
EHOSTUNREACH |
No route to host |
114 |
EALREADY |
Operation already in progress |
115 |
EINPROGRESS |
Operation now in progress |
116 |
117 |
EUCLEAN |
Structure needs cleaning |
118 |
ENOTNAM |
Not a XENIX named type file |
119 |
ENAVAIL |
No XENIX semaphores available |
120 |
EISNAM |
Is a named type file |
121 |
EREMOTEIO |
Remote I/O error |
122 |
EDQUOT |
Quota exceeded |
123 |
ENOMEDIUM |
No medium found |
124 |
EMEDIUMTYPE |
Wrong medium type |
125 |
ECANCELED |
Operation Canceled |
126 |
ENOKEY |
Required key not available |
127 |
EKEYEXPIRED |
Key has expired |
128 |
EKEYREVOKED |
Key has been revoked |
129 |
EKEYREJECTED |
Key was rejected by service |
130 |
EOWNERDEAD |
For robust mutexes: Owner died |
131 |
ENOTRECOVERABLE |
For robust mutexes: State not recoverable |
