Monitoring PUT and GET performance
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
You can monitor the performance of certain operations, such as object store and retrieve, to help identify changes that might require further investigation.
To monitor PUT and GET performance, you can run S3 and Swift commands directly from a workstation or by using the open-source S3tester application. Using these methods allows you to assess performance independently of factors that are external to StorageGRID, such as issues with a client application or issues with an external network.
When performing tests of PUT and GET operations, use the following guidelines:
Use object sizes comparable to the objects that you typically ingest into your grid.
Perform operations against both local and remote sites.
Messages in the audit log indicate the total time required to run certain operations. For example, to determine the total processing time for an S3 GET request, you can review the value of the TIME attribute in the SGET audit message. You can also find the TIME attribute in the audit messages for the following operations:
S3: DELETE, GET, HEAD, Metadata Updated, POST, PUT
Swift: DELETE, GET, HEAD, PUT
When analyzing results, look at the average time required to satisfy a request, as well as the overall throughput that you can achieve. Repeat the same tests regularly and record the results, so that you can identify trends that may require investigation.
You can download S3tester from github:https://github.com/s3tester
