Viewing the Events tab
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
The Events tab displays a count of any system error or fault events for a node, including errors such as network errors.
The Events tab is shown for all nodes.
If you experience issues with a particular node, you can use the Events tab to learn more about the issue. Technical support can also use the information on the Events tab to help with troubleshooting.
You can perform these tasks from the Events tab:
Use the information shown for the Last Event field at the top of the table to determine which event occurred most recently.
Click the chart icon for a specific event to see when that event occurred over time.
Reset event counts to zero after resolving any issues.
Related information
