What an object is
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
With object storage, the unit of storage is an object, rather than a file or a block. Unlike the tree-like hierarchy of a file system or block storage, object storage organizes data in a flat, unstructured layout. Object storage decouples the physical location of the data from the method used to store and retrieve that data.
Each object in an object-based storage system has two parts: object data and object metadata.
Object data
Object data might be anything; for example, a photograph, a movie, or a medical record.
Object metadata
Object metadata is any information that describes an object. StorageGRID uses object metadata to track the locations of all objects across the grid and to manage each object's lifecycle over time.
Object metadata includes information such as the following:
System metadata, including a unique ID for each object (UUID), the object name, the name of the S3 bucket or Swift container, the tenant account name or ID, the logical size of the object, the date and time the object was first created, and the date and time the object was last modified.
The current storage location of each object copy or erasure-coded fragment.
Any user metadata associated with the object.
Object metadata is customizable and expandable, making it flexible for applications to use.
For detailed information about how and where StorageGRID stores object metadata, go to Managing object metadata storage.
