Unable to connect to the appliance
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
If you cannot connect to the services appliance, there might be a network issue, or the hardware installation might not have been completed successfully.
Try to ping the appliance using the IP address for the appliance :
ping services_appliance_IP
If you receive no response from the ping, confirm you are using the correct IP address.
You can use the IP address of the appliance on the Grid Network, the Admin Network, or the Client Network.
If the IP address is correct, check appliance cabling, QSFP or SFP transceivers, and the network setup.
If that does not resolve the issue, contact technical support.
If the ping was successful, open a web browser.
Enter the URL for the StorageGRID Appliance Installer:
https://appliances_controller_IP:8443
The Home page appears.
