HE error: Error synchronizing with SANtricity OS Software
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
The seven-segment display on the compute controller shows an HE error code if the StorageGRID Appliance Installer cannot synchronize with SANtricity OS Software.
About this task
If an HE error code is displayed, perform this corrective action.
Steps
Check the integrity of the two SAS interconnect cables, and confirm they are securely connected.
As required, replace one or both of the cables, and try again.
If this does not resolve the issue, contact technical support.
