Replacing other hardware components
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
You might need to replace a drive, fan, power supply, or battery in the StorageGRID appliance.
You have the E-Series hardware replacement procedure.
The appliance has been placed maintenance mode if the component replacement procedure requires that you shut down the appliance.
To replace a drive, power-fan canister, fan canister, power canister, battery, or drive drawer, refer to the standard procedures for the E2700 and E5600 storage arrays. Focus on the step-by-step instructions for removing and replacing the hardware itself; many of the SANtricity Storage Manager procedures do not apply to an appliance.
SG5612 component replacement instructions
FRU | See |
Drive |
Follow the steps in the E-Series instructions for replacing a drive in the E2600, E2700, E5400, E5500, E5600 or 12-drive or 24-drive trays. |
Power-fan canister |
Follow the steps in the E-Series instructions for replacing a failed power-fan canister in the E5612 or the E5624 controller-drive tray. |
Battery in the E2700 controller (requires removing the controller) |
Follow the steps in Replacing the E2700 controller, but install the new battery in the existing controller. |
SG5660 component replacement instructions
FRU | See |
Drive |
Follow the steps in the E-Series instructions for replacing a drive in the E2660, E2760, E5460, E5560, or E5660 trays. |
Power canister |
Follow the steps in the E-Series instructions for replacing a failed power canister in the E5660 controller-drive tray. |
Fan canister |
Follow the steps in the E-Series instructions for replacing a failed fan canister in the E5660 controller-drive tray. |
NetApp E-Series and EF-Series Hardware Replacement Procedures
