Installation and deployment overview
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
You can install one or more StorageGRID storage appliances when you first deploy StorageGRID, or you can add appliance Storage Nodes later as part of an expansion. You might also need to install an appliance Storage Node as part of a recovery operation.
Your StorageGRID system is using the required version of StorageGRID software.
Appliance | Required StorageGRID version |
SG6060 with no expansion shelves |
11.1.1 or later |
SG6060 with expansion shelves (one or two) |
11.3 or later Note: If you add expansion shelves after the initial deployment, you must use version 11.4 or later. |
SGF6024 |
11.3 or later |
Installation and deployment tasks
Adding a StorageGRID storage appliance to a StorageGRID system includes four primary steps:
Preparing for installation:
Preparing the installation site
Unpacking the boxes and checking the contents
Obtaining additional equipment and tools
Gathering IP addresses and network information
Optional: Configuring an external key management server (KMS) if you plan to encrypt all appliance data. See details about external key management in the instructions for administering StorageGRID.
Installing the hardware:
Registering the hardware
Installing the appliance into a cabinet or rack
Installing the drives
Installing optional expansion shelves (model SG6060 only; maximum of two expansion shelves)
Cabling the appliance
Connecting the power cords and applying power
Viewing boot-up status codes
Configuring the hardware:
Accessing SANtricity System Manager to configure SANtricity System Manager settings
Accessing StorageGRID Appliance Installer, setting a static IP address for management port 1 on the storage controller, and configuring the link and network IP settings required to connect to StorageGRID networks
Accessing the baseboard management controller (BMC) interface on the SG6000-CN controller
Optional: Enabling node encryption if you plan to use an external KMS to encrypt appliance data.
Optional: Changing the RAID mode.
Deploying the appliance as a Storage Node:
Task Instructions Deploying an appliance Storage Node in a new StorageGRID system
Adding an appliance Storage Node to an existing StorageGRID system
Instructions for expanding a StorageGRID system
Deploying an appliance Storage Node as part of a Storage Node recovery operation
Instructions for recovery and maintenance
