Replacing a power supply in the SG6000-CN controller
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
The SG6000-CN controller has two power supplies for redundancy. If one of the power supplies fails, you must replace it as soon as possible to ensure that the compute controller has redundant power.
You have unpacked the replacement power supply unit.
You have physically located the controller where you are replacing the power supply in the data center.
You have confirmed that the other power supply is installed and running.
The figure shows the two power supply units for the SG6000-CN controller, which are accessible from the back of the controller.
Unplug the power cord from the power supply.
Lift the cam handle.
Press the blue latch and pull the power supply out.
Slide the replacement power supply into the chassis.
Ensure that the blue latch is on the right side when you slide the unit in.
Push the cam handle down to secure the power supply.
Attach the power cord to the power supply, and ensure that the green LED comes on.
