Guidelines for configuring an OpenLDAP server
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
If you want to use an OpenLDAP server for identity federation, you must configure specific settings on the OpenLDAP server.
Memberof and refint overlays
The memberof and refint overlays should be enabled. For more information, see the instructions for reverse group membership maintenance in the Administrator's Guide for OpenLDAP.
Indexing
You must configure the following OpenLDAP attributes with the specified index keywords:
olcDbIndex: objectClass eq olcDbIndex: uid eq,pres,sub olcDbIndex: cn eq,pres,sub olcDbIndex: entryUUID eq
In addition, ensure the fields mentioned in the help for Username are indexed for optimal performance.
See the information about reverse group membership maintenance in the Administrator's Guide for OpenLDAP.
