Installing Docker
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
The StorageGRID system runs on Linux as a collection of Docker containers. Before you can install StorageGRID, you must install Docker.
Steps
Install Docker by following the instructions for your Linux distribution.
If Docker is not included with your Linux distribution, you can download it from the Docker website. -
Ensure Docker has been enabled and started by running the following two commands:
sudo systemctl enable docker
sudo systemctl start docker
Confirm you have installed the expected version of Docker by entering the following:
sudo docker version
The Client and Server versions must be 1.10.3 or later.
Client: Version: 1.10.3 API version: 1.22 Go version: go1.6.1 Git commit: 20f81dd Built: Wed, 20 Apr 2016 14:19:16 -0700 OS/Arch: linux/amd64 Server: Version: 1.10.3 API version: 1.22 Go version: go1.6.1 Git commit: 20f81dd Built: Wed, 20 Apr 2016 14:19:16 -0700 OS/Arch: linux/amd64
Related information
