Downloading the StorageGRID upgrade files
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
You must download the required files to a service laptop before you upgrade your StorageGRID system.
You must have installed all required hotfixes for the StorageGRID software version you are upgrading. See the hotfix procedure in the recovery and maintenance instructions.
You must download the .upgrade
archive for any platform. If any nodes are deployed on Linux hosts, you must also download an RPM or DEB archive, which you will install before you start the upgrade.
Go to the NetApp Downloads page for StorageGRID.
Select the button for downloading the latest release, or select another version from the drop-down menu and select Go.
StorageGRID software versions have this format: 11.x.y. StorageGRID hotfixes have this format: 11.x.y.z.
Sign in with the username and password for your NetApp account.
If a Caution/MustRead statement appears, read it and select the check box.
This statement appears if there is a required hotfix for the release.
Read the End User License Agreement, select the check box, and then select Accept & Continue.
The downloads page for the version you selected appears. The page contains three columns:
Install StorageGRID
Upgrade StorageGRID
Support files for StorageGRID Appliances
In the Upgrade StorageGRID column, select and download the
.upgrade
archive.Every platform requires the
.upgrade
archive. -
If any nodes are deployed on Linux hosts, also download the RPM or DEB archive in either
.tgz
or.zip
format.You must install the RPM or DEB archive on all Linux nodes before you start the upgrade.
No additional files are required for the SG100 or SG1000. Select the .zip
file if you are running Windows on the service laptop.-
Red Hat Enterprise Linux or CentOS
StorageGRID-Webscale-version-RPM-uniqueID.zip
StorageGRID-Webscale-version-RPM-uniqueID.tgz
Ubuntu or Debian
StorageGRID-Webscale-version-DEB-uniqueID.zip
StorageGRID-Webscale-version-DEB-uniqueID.tgz
