Virtual machine resource reservation requires adjustment
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
OVF files include a resource reservation designed to ensure that each grid node has sufficient RAM and CPU to operate efficiently. If you create virtual machines by deploying these OVF files on VMware and the predefined number of resources are not available, the virtual machines will not start.
If you are certain that the VM host has sufficient resources for each grid node, manually adjust the resources allocated for each virtual machine, and then try starting the virtual machines.
In the VMware vSphere Hypervisor client tree, select the virtual machine that is not started.
Right‐click the virtual machine, and select Edit Settings.
From the Virtual Machines Properties window, select the Resources tab.
Adjust the resources allocated to the virtual machine:
Select CPU, and then use the Reservation slider to adjust the MHz reserved for this virtual machine.
Select Memory, and then use the Reservation slider to adjust the MB reserved for this virtual machine.
Click OK.
Repeat as required for other virtual machines hosted on the same VM host.
