Known limitations for OnCommand Workflow Automation
PDF of this doc site
- Installation and setup for Linux
- Installation and setup for Windows
Creating your file...
OnCommand Workflow Automation (WFA) 5.0 includes some limitations and unsupported features that you should be aware of before you install and configure WFA.
LDAP authentication
You can use only Microsoft Active Directory Lightweight Directory Access Protocol (LDAP) server for LDAP authentication.
You must not use an LDAP user name that is part of a hierarchical structure of multiple domains for authentication or notification.
Microsoft Active Directory Lightweight Directory Services (AD LDS) is not supported. |
WFA data sources types
Active IQ Data Center Manager 6.0, 6.1, and 6.2 data source types are deprecated in the WFA 4.1 release, and these data source types will not be supported in future releases.
WFA installed on Linux
Certified content from Data ONTAP operating in 7-Mode is currently not available.
Commands that include only PowerShell code are not compatible with Linux.
Certified commands for 7-Mode and VMware are currently not ported to Perl, and are therefore not compatible with Linux.
