Related documentation for OnCommand Workflow Automation
PDF of this doc site
Installation and setup for Linux
- Installation and setup for Windows
Creating your file...
Your file is ready
There are additional documents and tools to help you learn to perform more advanced configuration of your OnCommand Workflow Automation (WFA) server.
Other references
The Workflow Automation space within the NetApp community provides additional learning resources, including the following:
NetApp community
Tool references
Interoperability Matrix
Lists supported combinations of hardware components and software versions.
