Create a new account
Beitragende
POST /accounts
Indicates the desired values for the Account API resource to be created.
Request Body
type
string
True
  • "application/astra-account"
version
string
True
  • "1.0"
name
string
True
JSON string containing a name for the account. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
  • This string is internally validated to prevent XSS, Unicode, directory traversal, and SQL-injection attacks.
metadata
type_astra_metadata_update
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
Example request
  "type": "application/astra-account",
  "version": "1.0",
  "name": "Testing 123"
Status: 201, Returns the newly created account resource in the JSON response body.
type
string
True
version
string
True
  • "1.0"
id
string
True
name
string
True
  • Minimum length: 1
state
string
True
JSON string containing a value indicating the operational state of the account. Defined values are:
  • "pending" - Changes can only be made to user and role resources under the account (default value)
  • "active" - Changes can be made to any resource under the account
  • "deletePending" - Users cannot log in, data protection operations are suspended, charges no longer accrue
isEnabled
string
True
JSON string indicating the account is enabled. Defined values are:
  • "false" - Users are not permitted to use this account
  • "true" - Users are permitted to use this account
enabledTimestamp
string
False
JSON string containing the timestamp indicating when the account was last enabled. If the account has never been enabled, this field is absent. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
accountContact
accountContact
False
JSON object containing user contact information to create an owner user at the time of account activation.
metadata
True
  "version": "1.0",
  "id": "666a3f38-d4fa-5b62-a391-a69029758d32",
  "name": "fraught-pines",
  "state": "pending",
  "isEnabled": "false",
  "enabledTimestamp": "2020-08-06T12:24:52.256624Z",
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
Status: 409, Conflict
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidFields
False
  "status": "409"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
postalAddress
JSON object containing a collection of JSON strings specifying an address. If this key does not exist, it indicates that an address has not been provided. If this key exists, all six of the contained JSON strings will be present. If you provide nothing, the string will be empty.
addressCountry
string
True
JSON string containing the country name or country code associated with the postal address, as specified in ISO 3166 Alpha-2. Defined values are:
  • Minimum length: 2
  • Maximum length: 2
addressLocality
string
True
JSON string containing the locality (for example, city) associated with the postal address. Defined values are:
  • Minimum length: 1
addressRegion
string
True
JSON string containing the region (for example, state) associated with the postal address. Defined values are:
  • Minimum length: 1
postalCode
string
True
JSON string containing the postal code associated with the postal address. Defined values are:
  • Minimum length: 1
  • Maximum length: 31
streetAddress1
string
True
JSON string containing the street address associated with the postal address. Defined values are:
  • Minimum length: 1
streetAddress2
string
False
JSON string containing optional ancillary street address information, post office box, and more. Defined values are:
  • Minimum length: 1
accountContact
firstName
string
True
JSON string containing a user specified long-form first name. Defined values are:
  • Minimum length: 1
lastName
string
True
JSON string containing a user specified long-form last name. Defined values are:
  • Minimum length: 1
companyName
string
False
JSON string containing the company name associated with the user. If this key does not exist, it indicates that a company name has not been provided. Defined values are:
  • Minimum length: 1
email
string
True
JSON strings containing a user specified email address. Defined values are:
  • Minimum length: 1
phone
string
False
JSON string containing the phone number of the user. If this key does not exist, it indicates that a phone number has not been provided. Defined values are:
  • Minimum length: 1
postalAddress
postalAddress
True
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
