Migración de datos CIFS con ACL desde un servidor de almacenamiento de origen a ONTAP
Esta sección cubre el procedimiento paso a paso para migrar datos CIFS con información de seguridad desde un sistema ONTAP de origen a un sistema ONTAP de destino.
Verifique que el sistema ONTAP de destino esté en buen estado.
C1_sti96-vsim-ucs540m_cluster::> cluster show Node Health Eligibility --------------------- ------- ------------ sti96-vsim-ucs540m true true sti96-vsim-ucs540n true true 2 entries were displayed. C1_sti96-vsim-ucs540m_cluster::> node show Node Health Eligibility Uptime Model Owner Location --------- ------ ----------- ------------- ----------- -------- --------------- sti96-vsim-ucs540m true true 15 days 21:17 SIMBOX ahammed sti sti96-vsim-ucs540n true true 15 days 21:17 SIMBOX ahammed sti 2 entries were displayed. cluster::> storage failover show Takeover Node Partner Possible State Description -------------- -------------- -------- ------------------------------------- sti96-vsim-ucs540m sti96-vsim- true Connected to sti96-vsim-ucs540n ucs540n sti96-vsim-ucs540n sti96-vsim- true Connected to sti96-vsim-ucs540m ucs540m 2 entries were displayed. C1_sti96-vsim-ucs540m_cluster::> -
Verifique que exista al menos un agregado no raíz en el sistema de destino. El agregado es normal.
cluster::*> storage aggregate show Aggregate Size Available Used% State #Vols Nodes RAID Status --------- -------- --------- ----- ------- ------ ---------------- ------------ aggr0_sti96_vsim_ucs540o 7.58GB 373.3MB 95% online 1 sti96-vsim- raid_dp, ucs540o normal aggr0_sti96_vsim_ucs540p 7.58GB 373.3MB 95% online 1 sti96-vsim- raid_dp, ucs540p normal aggr_001 103.7GB 93.63GB 10% online 1 sti96-vsim- raid_dp, ucs540p normal sti96_vsim_ucs540o_aggr1 23.93GB 23.83GB 0% online 1 sti96-vsim- raid_dp, ucs540o normal sti96_vsim_ucs540p_aggr1 23.93GB 23.93GB 0% online 0 sti96-vsim- raid_dp, ucs540p normal 5 entries were displayed.Si no hay ningún agregado de datos, cree uno nuevo utilizando el storage aggr createdominio. -
Cree una SVM en el sistema de clúster de destino.
cluster::*> vserver create -vserver vs1 -rootvolume root_vs1 -aggregate sti96_vsim_ucs540o_aggr1 -rootvolume-security-style mixed Verify that the SVM was successfully created. C2_sti96-vsim-ucs540o_cluster::*> vserver show -vserver vs1 Vserver: vs1 Vserver Type: data Vserver Subtype: default Vserver UUID: f8bc54be-d91b-11e9-b99c-005056a7e57e Root Volume: root_vs1 Aggregate: sti96_vsim_ucs540o_aggr1 NIS Domain: NSQA-RTP-NIS1 Root Volume Security Style: mixed LDAP Client: esisconfig Default Volume Language Code: C.UTF-8 Snapshot Policy: default Data Services: data-nfs, data-cifs, data-flexcache, data-iscsi Comment: vs1 Quota Policy: default List of Aggregates Assigned: - Limit on Maximum Number of Volumes allowed: unlimited Vserver Admin State: running Vserver Operational State: running Vserver Operational State Stopped Reason: - Allowed Protocols: nfs, cifs, fcp, iscsi, ndmp Disallowed Protocols: - Is Vserver with Infinite Volume: false QoS Policy Group: - Caching Policy Name: - Config Lock: false Volume Delete Retention Period: 0 IPspace Name: Default Foreground Process: - Is Msid Preserved for DR: false Force start required to start Destination in muliple IDP fan-out case: false Logical Space Reporting: false Logical Space Enforcement: false -
Cree un nuevo volumen de datos de lectura y escritura en el SVM de destino. Verifique que el estilo de seguridad, la configuración de idioma y los requisitos de capacidad coincidan con el volumen de origen.
CLUSTER CLUSTER::> vol create -vserver vs1 -volume dest_vol -aggregate aggr_001 -size 150g type RW -state online -security-style ntfs
Cree un LIF de datos para atender solicitudes de clientes SMB.
CLUSTER::> network interface create -vserver vs1 -lif sti96-vsim-ucs540o_data1 -address 10.237.165.87 -netmask 255.255.240.0 -role data -data-protocol nfs,cifs -home-node sti96-vsim-ucs540o -home-port e0d
Verifique que el LIF se haya creado correctamente.
cluster::*> network interface show -vserver vs1 Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- vs1 sti96-vsim-ucs540o_data1 up/up 10.237.165.87/20 sti96-vsim-ucs540o e0d true -
Si es necesario, cree una ruta estática con la SVM.
Network route create -vserver dest -destination 0.0.0.0/0 -gateway 10.237.160.1
Verifique que la ruta se haya creado correctamente.
cluster::*> network route show -vserver vs1 Vserver Destination Gateway Metric ------------------- --------------- --------------- ------ vs1 0.0.0.0/0 10.237.160.1 20 ::/0 fd20:8b1e:b255:9155::1 20 2 entries were displayed. -
Monte el volumen de datos de destino en el espacio de nombres SVM.
CLUSTER::> volume mount -vserver vs1 -volume dest_vol -junction-path /dest_vol -active true
Verifique que el volumen esté montado correctamente.
cluster::*> volume show -vserver vs1 -fields junction-path vserver volume junction-path ------- -------- ------------- vs1 dest_vol /dest_vol vs1 root_vs1 / 2 entries were displayed. Note: You can also specify the volume mount options (junction path) with the volume create command.
Inicie el servicio CIF en el SVM de destino.
cluster::*> vserver cifs start -vserver vs1 Warning: The admin status of the CIFS server for Vserver "vs1" is already "up".
Verifique que el servicio esté iniciado y en ejecución.
cluster::*> Verify the service is started and running C2_sti96-vsim-ucs540o_cluster::*> cifs show Server Status Domain/Workgroup Authentication Vserver Name Admin Name Style ----------- --------------- --------- ---------------- -------------- vs1 D60AB15C2AFC4D6 up CTL domain -
Verifique que la política de exportación predeterminada se aplique al SVM de destino.
CLUSTER::> vserver export-policy show -vserver dest Vserver Policy Name --------------- ------------------- dest default
Si es necesario, cree una nueva política de exportación personalizada para el SVM de destino.
CLUSTER::> vserver export-policy create -vserver vs1 -policyname xcpexport
Modificar las reglas de la política de exportación para permitir el acceso a clientes CIF.
CLUSTER::> export-policy rule modify -vserver dest -ruleindex 1 -policyname xcpexportpolicy -clientmatch 0.0.0.0/0 -rorule any -rwrule any -anon 0
Verificar que las reglas de la política se modifiquen.
cluster::*> export-policy rule show -instance Vserver: vs1 Policy Name: default Rule Index: 1 Access Protocol: any List of Client Match Hostnames, IP Addresses, Netgroups, or Domains: 0.0.0.0/0 RO Access Rule: any RW Access Rule: any User ID To Which Anonymous Users Are Mapped: 65534 Superuser Security Types: any Honor SetUID Bits in SETATTR: true Allow Creation of Devices: true NTFS Unix Security Options: fail Vserver NTFS Unix Security Options: use_export_policy Change Ownership Mode: restricted Vserver Change Ownership Mode: use_export_policy Policy ID: 12884901889 Vserver: vs1 Policy Name: default Rule Index: 2 Access Protocol: any List of Client Match Hostnames, IP Addresses, Netgroups, or Domains: 0:0:0:0:0:0:0:0/0 RO Access Rule: any RW Access Rule: any User ID To Which Anonymous Users Are Mapped: 65534 Superuser Security Types: none Honor SetUID Bits in SETATTR: true Allow Creation of Devices: true NTFS Unix Security Options: fail Vserver NTFS Unix Security Options: use_export_policy Change Ownership Mode: restricted Vserver Change Ownership Mode: use_export_policy Policy ID: 12884901889 2 entries were displayed. -
Verifique que el cliente tenga permitido el acceso al volumen.
cluster::*> export-policy check-access -vserver vs1 -volume dest_vol -client-ip 10.234.17.81 -authentication-method none -protocol cifs -access-type read-write Policy Policy Rule Path Policy Owner Owner Type Index Access ----------------------------- ---------- --------- ---------- ------ ---------- / default root_vs1 volume 1 read /dest_vol default dest_vol volume 1 read-write 2 entries were displayed. -
Conéctese al sistema cliente Windows donde está instalado XCP. Busque la ruta de instalación de XCP.
C:\WRSHDNT>dir c:\netapp\xcp dir c:\netapp\xcp Volume in drive C has no label. Volume Serial Number is 5C04-C0C7 Directory of c:\netapp\xcp 09/18/2019 09:30 AM <DIR> . 09/18/2019 09:30 AM <DIR> .. 06/25/2019 06:27 AM 304 license 09/18/2019 09:30 AM <DIR> Logs 09/29/2019 08:45 PM 12,143,105 xcp.exe 2 File(s) 12,143,409 bytes 3 Dir(s) 29,219,549,184 bytes free -
Consulte las exportaciones SMB del nodo de origen ejecutando el comando
xcp showcomando en el sistema host del cliente Windows XCP.C:\WRSHDNT>c:\netapp\xcp\xcp show \\10.237.165.71 c:\netapp\xcp\xcp show \\10.237.165.71 XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Mon Dec 31 00:00:00 2029 Shares Errors Server 6 0 10.237.165.71 == SMB Shares == Space Space Current Free Used Connections Share Path Folder Path 9.50GiB 4.57MiB 1 \\10.237.165.71\source_share C:\source_vol 94.3MiB 716KiB 0 \\10.237.165.71\ROOTSHARE C:\ 0 0 N/A \\10.237.165.71\ipc$ N/A 94.3MiB 716KiB 0 \\10.237.165.71\c$ C:\ == Attributes of SMB Shares == Share Types Remark source_share DISKTREE test share DISKTREE test_sh DISKTREE ROOTSHARE DISKTREE \"Share mapped to top of Vserver global namespace, created bydeux_init \" ipc$ PRINTQ,SPECIAL,IPC,DEVICE c$ SPECIAL == Permissions of SMB Shares == Share Entity Type source_share Everyone Allow/Full Control ROOTSHARE Everyone Allow/Full Control ipc$ Everyone Allow/Full Control c$ Administrators Allow/Full Control/ -
Ejecutar el
helpComando para copiar.C:\WRSHDNT>c:\netapp\xcp\xcp help copy c:\netapp\xcp\xcp help copy XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Mon Dec 31 00:00:00 2029 usage: xcp copy [-h] [-v] [-parallel <n>] [-match <filter>] [-preserve-atime] [-acl] [-fallback-user FALLBACK_USER] [-fallback-group FALLBACK_GROUP] [-root] source target positional arguments: source target optional arguments: -h, --help show this help message and exit -v increase debug verbosity -parallel <n> number of concurrent processes (default: <cpu-count>) -match <filter> only process files and directories that match the filter (see `xcp help -match` for details) -preserve-atime restore last accessed date on source -acl copy security information -fallback-user FALLBACK_USER the name of the user on the target machine to receive the permissions of local (non-domain) source machine users (eg. domain\administrator) -fallback-group FALLBACK_GROUP the name of the group on the target machine to receive the permissions of local (non-domain) source machine groups (eg. domain\administrators) -root copy acl for root directorytxt -
En el sistema ONTAP de destino, obtenga la lista de nombres de usuarios y grupos locales que necesita proporcionar como valores para
fallback-useryfallback-groupruta de argumentos.cluster::*> local-user show (vserver cifs users-and-groups local-user show) Vserver User Name Full Name Description ------------ --------------------------- -------------------- ------------- vs1 D60AB15C2AFC4D6\Administrator Built-in administrator account C2_sti96-vsim-ucs540o_cluster::*> local-group show (vserver cifs users-and-groups local-group show) Vserver Group Name Description -------------- -------------------------------- ---------------------------- vs1 BUILTIN\Administrators Built-in Administrators group vs1 BUILTIN\Backup Operators Backup Operators group vs1 BUILTIN\Guests Built-in Guests Group vs1 BUILTIN\Power Users Restricted administrative privileges vs1 BUILTIN\Users All users 5 entries were displayed -
Para migrar los datos CIF con ACL desde el origen al destino, ejecute el comando
xcp copyComando con el-acly–fallback-user/groupopciones.Para el
fallback-user/groupopciones, especifique cualquier usuario o grupo que se pueda encontrar en Active Directory o usuario/grupo local en el sistema de destino.C:\WRSHDNT>c:\netapp\xcp\xcp copy -acl -fallback-user D60AB15C2AFC4D6\Administrator -fallback-group BUILTIN\Users \\10.237.165.79\source_share \\10.237.165.89\dest_share c:\netapp\xcp\xcp copy -acl -fallback-user D60AB15C2AFC4D6\Administrator -fallback-group BUILTIN\Users \\10.237.165.79\source_share \\10.237.165.89\dest_share XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Mon Dec 31 00:00:00 2029 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 8s 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 13s 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 18s ERROR failed to obtain fallback security principal "BUILTIN\Users". Please check if the principal with the name "BUILTIN\Users" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\Administrator". Please check if the principal with the name "D60AB15C2AFC4D6\Administrator" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "BUILTIN\Users". Please check if the principal with the name "BUILTIN\Users" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "BUILTIN\Users". Please check if the principal with the name "BUILTIN\Users" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "BUILTIN\Users". Please check if the principal with the name "BUILTIN\Users" exists on "D60AB15C2AFC4D6". 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 23s ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\Administrator". Please check if the principal with the name "D60AB15C2AFC4D6\Administrator" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\Administrator". Please check if the principal with the name "D60AB15C2AFC4D6\Administrator" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\Administrator". Please check if the principal with the name "D60AB15C2AFC4D6\Administrator" exists on "D60AB15C2AFC4D6". 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 28s 753 scanned, 0 errors, 0 skipped, 249 copied, 24.0KiB (4.82KiB/s), 33s 753 scanned, 0 errors, 0 skipped, 744 copied, 54.4KiB (6.07KiB/s), 38s 753 scanned, 0 errors, 0 skipped, 746 copied, 54.5KiB (20/s), 43s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (1.23KiB/s), 44s C:\WRSHDNT>
Si
xcp copyda como resultado el mensaje de errorERROR failed to obtain fallback security principal, agregue el cuadro de destino en el archivo de hosts(C:\Windows\System32\drivers\etc\hosts).Utilice el siguiente formato para la entrada del cuadro de destino de almacenamiento de NetApp .
<data vserver data interface ip> 1 or more white spaces <cifs server name>
cluster::*> cifs show Server Status Domain/Workgroup Authentication Vserver Name Admin Name Style ----------- --------------- --------- ---------------- -------------- vs1 D60AB15C2AFC4D6 up CTL domain C2_sti96-vsim-ucs540o_cluster::*> network interface show Logical Status Network Current Current Is Cluster sti96-vsim-ucs540p_clus1 up/up 192.168.148.136/24 sti96-vsim-ucs540p e0a true sti96-vsim-ucs540p_clus2 up/up 192.168.148.137/24 sti96-vsim-ucs540p e0b true vs1 sti96-vsim-ucs540o_data1 up/up 10.237.165.87/20 sti96-vsim-ucs540o e0d true sti96-vsim-ucs540o_data1_inet6 up/up fd20:8b1e:b255:9155::583/64 sti96-vsim-ucs540o e0d true sti96-vsim-ucs540o_data2 up/up 10.237.165.88/20 sti96-vsim-ucs540o e0e true 10.237.165.87 D60AB15C2AFC4D6 -> destination box entry to be added in hosts file. -
Si sigue recibiendo el mensaje de error
ERROR failed to obtain fallback security principalDespués de agregar la entrada del cuadro de destino en los archivos de hosts, el usuario/grupo no existe en el sistema de destino.C:\WRSHDNT>c:\netapp\xcp\xcp copy -acl -fallback-user D60AB15C2AFC4D6\unknown_user -fallback-group BUILTIN\Users \\10.237.165.79\source_share \\10.237.165.89\dest_share c:\netapp\xcp\xcp copy -acl -fallback-user D60AB15C2AFC4D6\unknown_user -fallback-group BUILTIN\Users \\10.237.165.79\source_share \\10.237.165.89\dest_share XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Mon Dec 31 00:00:00 2029 ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\unknown_user". Please check if the principal with the name "D60AB15C2AFC4D6\unknown_user" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\unknown_user". Please check if the principal with the name "D60AB15C2AFC4D6\unknown_user" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\unknown_user". Please check if the principal with the name "D60AB15C2AFC4D6\unknown_user" exists on "D60AB15C2AFC4D6". ERROR failed to obtain fallback security principal "D60AB15C2AFC4D6\unknown_user". Please check if the principal with the name "D60AB15C2AFC4D6\unknown_user" exists on "D60AB15C2AFC4D6". 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 5s 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 10s 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 15s 753 scanned, 0 errors, 0 skipped, 284 copied, 27.6KiB (5.54KiB/s), 20s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (2.44KiB/s), 22s C:\WRSHDNT>
Usar
xcp copypara migrar datos CIF con ACL (con o sin la carpeta raíz).Sin la carpeta raíz, ejecute los siguientes comandos:
C:\WRSHDNT>c:\netapp\xcp\xcp copy -acl -fallback-user D60AB15C2AFC4D6\Administrator -fallback-group BUILTIN\Users \\10.237.165.79\source_share \\10.237.165.89\dest_share c:\netapp\xcp\xcp copy -acl -fallback-user D60AB15C2AFC4D6\Administrator -fallback-group BUILTIN\Users \\10.237.165.79\source_share \\10.237.165.89\dest_share XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Mon Dec 31 00:00:00 2029 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 5s 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 10s 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 15s 753 scanned, 0 errors, 0 skipped, 210 copied, 20.4KiB (4.08KiB/s), 20s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (2.38KiB/s), 22s C:\WRSHDNT>
Con la carpeta raíz, ejecute los siguientes comandos:
C:\WRSHDNT>c:\netapp\xcp\xcp copy -acl -root -fallback-user D60AB15C2AFC4D6\Administrator -fallback-group BUILTIN\Users \\10.237.165.79\source_share \\10.237.165.89\dest_share c:\netapp\xcp\xcp copy -acl -root -fallback-user D60AB15C2AFC4D6\Administrator -fallback-group BUILTIN\Users \\10.237.165.79\source_share \\10.237.165.89\dest_share XCP SMB 1.6; (c) 2020 NetApp, Inc.; Licensed to XXX [NetApp Inc] until Mon Dec 31 00:00:00 2029 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 5s 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 10s 753 scanned, 0 errors, 0 skipped, 0 copied, 0 (0/s), 15s 753 scanned, 0 errors, 0 skipped, 243 copied, 23.6KiB (4.73KiB/s), 20s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (6.21KiB/s), 25s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 30s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 35s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 40s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 45s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 50s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 55s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 1m0s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (0/s), 1m5s 753 scanned, 0 errors, 0 skipped, 752 copied, 54.7KiB (817/s), 1m8s C:\WRSHDNT>
