Obtenga información acerca de cómo responder al estado del sistema ONTAP degradado
Al revisar un ejemplo específico de estado del sistema degradado causado por una bandeja que carece de dos rutas a un nodo, puede ver lo que muestra la CLI cuando responde a una alerta.
Después de iniciar ONTAP, compruebe el estado del sistema y detecte que el estado es degradado:
cluster1::>system health status show
Status
degraded
Muestra las alertas para averiguar dónde está el problema y ver que la bandeja 2 no tiene dos rutas al nodo 1:
cluster1::>system health alert show
Node: node1
Resource: Shelf ID 2
Severity: Major
Indication Time: Mon Nov 10 16:48:12 2013
Probable Cause: Disk shelf 2 does not have two paths to controller
node1.
Possible Effect: Access to disk shelf 2 via controller node1 will be
lost with a single hardware component failure (e.g.
cable, HBA, or IOM failure).
Corrective Actions: 1. Halt controller node1 and all controllers attached to disk shelf 2.
2. Connect disk shelf 2 to controller node1 via two paths following the rules in the Universal SAS and ACP Cabling Guide.
3. Reboot the halted controllers.
4. Contact support personnel if the alert persists.
Se muestran detalles de la alerta para obtener más información, incluido el ID de alerta:
cluster1::>system health alert show -monitor node-connect -alert-id DualPathToDiskShelf_Alert -instance
Node: node1
Monitor: node-connect
Alert ID: DualPathToDiskShelf_Alert
Alerting Resource: 50:05:0c:c1:02:00:0f:02
Subsystem: SAS-connect
Indication Time: Mon Mar 21 10:26:38 2011
Perceived Severity: Major
Probable Cause: Connection_establishment_error
Description: Disk shelf 2 does not have two paths to controller node1.
Possible Effect: Access to disk shelf 2 via controller node1 will be lost with a single
hardware component failure (e.g. cable, HBA, or IOM failure).
Acknowledge: false
Suppress: false
Policy: DualPathToDiskShelf_Policy
Acknowledger: -
Suppressor: -
Additional Information: Shelf uuid: 50:05:0c:c1:02:00:0f:02
Shelf id: 2
Shelf Name: 4d.shelf2
Number of Paths: 1
Number of Disks: 6
Adapter connected to IOMA:
Adapter connected to IOMB: 4d
Alerting Resource Name: Shelf ID 2
Reconoce la alerta para indicar que está trabajando en ella.
cluster1::>system health alert modify -node node1 -alert-id DualPathToDiskShelf_Alert -acknowledge true
Fije el cableado entre la bandeja 2 y la nodo 1 y, a continuación, reinicie el sistema. A continuación, vuelva a comprobar el estado del sistema y compruebe que el estado es OK:
Status
OK
Información relacionada
